KnurledNut
Check out their hex and torx keys and folders. It's pretty obvious. They source from Bondhus too.What did snap on source from elkind?
One of the better local hardware stores in Philly has a full Eklind display, or they used to.Eklind has long been a widely-stocked brick and mortar item, made in America, and sold at a very affordable price.
Maybe Snap-on will start manufacturing the tools they were sourcing from Eklind.
I did exactly that last week.... But I switched to a screwdriver style with a ball head.For mechanical stuff, I’ll take SAE & metric sets to the fastener and see which fits best. Once I know the size, I usually switch to a bit socket + ratchet. L keys get the job done but I don’t really like using them for some strange reason
I have the metric set. I believe the keys are Eklind. Mine have the signature undressed shear cut ends, except for the 12mm which was lathe finished.Are their zinc finished hex keys are made in house ? I’d assume so, based off the resemblance to their hex bit sockets
EklindDo we know if Snap-On sourced the Williams US made L key sets from Eklind or from Bahco? I've used those for years and they've been great
One of my best friends retired from aircraft manufacturing. It's amazing to me how much "hand fitting" they had to do to build run of the mill planes. His job the last several years was to fly to the company's various factories and show them how to make parts fit or how to make parts that fit. When I hear aerospace quality, I laugh. The tech, precision, and accuracy that goes into a turbine engine does not go into the rest of the planeIt's as if it was 1900 and interchangeable parts hadn't been popularized yet.
I despise the fold out sets. I know they are good for travel since there's no little pieces to lose, but they are awful to use.For handyman type stuff, the fold out sets are great as they don’t get lost and access usually isn’t an issue.
I believe Eklind makes the one for Snap-on that is a combination of torx and hex sizes for Harley Davidson. An application that makes sense since its motorcycle kit friendly and you'll probably be needing it.I despise the fold out sets. I know they are good for travel since there's no little pieces to lose, but they are awful to use.
-While I was a die maker there in the mid 90's the fold-up sets for SO were sourced from Eklind. I changed the stamp for several brands sourced from Eklind. It's a rather common practice in manufacturing, it's sometimes called "house branding". The "L" keys for others used to have an "ET" stamped on the body instead of the full Eklind Tool logo. Don't know what they did after I left but I suspect that remained.What did snap on source from elkind?
I'm curious all you hex key users, what do you grab first?
An L, fold out set of keys , regular screwdriver shape, T shape, or bits?
For portability (like a set to carry on a bicycle ) I'll probably grab fold out set of keys. If portability is my concern more often than not. If I'm around my tools, I probably just grab a screwdriver shape. I have a couple T handle sizes when I know I'm going to want more torque.
That said, if I'm pulling tools to the work and I don't really know I'm going to need. I grab one of those big bit sets I put together that has ball hacks and regular hacks and then a couple adapters and allowed. We can get links and then I can throw it in either one of my ratcheting screwdrivers or use a battery powered driver.
I think almost all of my hex drivers that are not bits are bondhus.
Sorry to see them close though
Snap-on folding Allen and Torx sets and Blue Point L-keys for staters. There were probably a few other things.What did snap on source from elkind?
All I own or have looked at are the L wrenches and bit sockets, which are clearly Bondhus. Never had interest in the folder sets but looking at th catalog yeah they're probably elkind.Check out their hex and torx keys and folders. It's pretty obvious. They source from Bondhus too.
The dimple on Eklind is deeper than the Chesco. That tells me maybe not a rebrand, but another maker. The cheap import is similar but thinner tin and less dimensions.
Did Eklind produce keys for Chesco? Or might that have been one of the competitors?-While I was a die maker there in the mid 90's the fold-up sets for SO were sourced from Eklind. I changed the stamp for several brands sourced from Eklind. It's a rather common practice in manufacturing, it's sometimes called "house branding". The "L" keys for others used to have an "ET" stamped on the body instead of the full Eklind Tool logo. Don't know what they did after I left but I suspect that remained.
Doubtful it's plated in tin.. The cheap import is similar but thinner tin and less dimensions.
Do you know if they made the socket bits for the gold Hd hex and torx bit sockets?-While I was a die maker there in the mid 90's the fold-up sets for SO were sourced from Eklind. I changed the stamp for several brands sourced from Eklind. It's a rather common practice in manufacturing, it's sometimes called "house branding". The "L" keys for others used to have an "ET" stamped on the body instead of the full Eklind Tool logo. Don't know what they did after I left but I suspect that remained.
Machine and weld up some allen cheaters. I always cut the tube at 30 degrees for the end but some do it a little steeper. Makes using keys a lot more comfortable, especially tight cap screws when they break free, your hands wont smart from it. I made them out of 3/8" tubing for smaller keys and 1/2". Some guys made them from larger tube as well but I never had issues getting a 1/2" drive or 3/4" drive ratchet in the places needed for the large 17mm and 19mm allen cap screws. The smaller sizes many times you couldn't get a ratchet head into place especially around ball screw nuts so the cheaters helped tremendouslyCan't say I have heard of this brand. I like my Bondhus, though they always annoyed me not selling a long series. We used allen keys all the time in the tool and die shop.
Never had any issues. I broke a few but that was because I was swinging on them on something way too tight. So I would just shrug my shoulders, say "it had a good life" and would buy another one. Have never had an issue with replacing tools that broke after giving me many years of good use.
I just use whatever box and wrenches handy. A cheater pipe would feel nicer on the hand and easier to set up, but I never want to go get another tool.Machine and weld up some allen cheaters. I always cut the tube at 30 degrees for the end but some do it a little steeper. Makes using keys a lot more comfortable, especially tight cap screws when they break free, your hands wont smart from it. I made them out of 3/8" tubing for smaller keys and 1/2". Some guys made them from larger tube as well but I never had issues getting a 1/2" drive or 3/4" drive ratchet in the places needed for the large 17mm and 19mm allen cap screws. The smaller sizes many times you couldn't get a ratchet head into place especially around ball screw nuts so the cheaters helped tremendously
-I don't recall seeing a Chesco stamp but that doesn't mean they didn't before or after I left. The Eklind made hex keys had a somewhat distinctive black(ish) color from heat treating that was purposely done (so I was told) to provide a visual difference from the other brands.Did Eklind produce keys for Chesco? Or might that have been one of the competitors?
-Photos help so I know what you're referring to.Do you know if they made the socket bits for the gold Hd hex and torx bit sockets?
They have a 12" long set, albeit only in the SAE sizes.Can't say I have heard of this brand. I like my Bondhus, though they always annoyed me not selling a long series.
I use fusion 360 but that is just an internet image that I found so I didn't have to go out to the shop and dig mine out.We made our own T Handles like that for getting into deep areas. Out of curiosity what software are you using?
I just bought 2 new sets from Menards on sale a few months ago. They're hardly any more expensive than HF, and way better.Where is (was) their market?
-The "signature undressed shear cut ends" are not always indicative of Eklind. IIRC there were/are a few other brands that had shear cut ends. It's only in the last two decades or so that makers began to finish the ends for the sake of visual appeal that the marketing dept. likely advocated. The appearance of the end is due to the type of steel the hex key is made from, how sharp both top/bottom are in the parting station, and the die clearance used. Even the timing of the die, stripper and spring preload can make a difference in clean the end looks. Just FYI, not a critique or disagreement with your evaluation.I believe the keys are Eklind. Mine have the signature undressed shear cut ends, except for the 12mm which was lathe finished.
-Not necessarily, the "dimple" is a die component that can be easily changed/replaced during routine die maintenance. Dimple punch gets re-made or the set height is changed for various reasons. Furthermore, the two examples you've used are completely different handles made with completely different dies, even the profile of the dimple is different. You cannot scale down one for another and expect them to be identical for several reasons. You have a good eye for detail but a lack of knowledge with how stamping dies are designed/constructed.The dimple on Eklind is deeper than the Chesco. That tells me maybe not a rebrand, but another maker.
-If you're referring to the bend radius of the sides that doesn't mean what you're suggesting it does.Look at the side profile of the handle. 90 degree on Eklind, curved on Chesco. The yellow imports copy Eklind.
Probably competition.
